Here are some shots of my recently converted Topcor RE 35mm f2.8 to PK mount with aperture control.
This was not an easy project for me but a lot of trial and error finally got me a working version.
Its not very pretty but it does work.
Unfortunatly my K5 is being repaired so I cant really test it yet
When testing using an old Pentax A3 it works well. I can focus wide open and the camera will close the aperture when I take the shot.
its an amazingly nice lens and being able to use it on my K5 is thrilling!.
It focuses down to 23cm from filmplane and that is almost macroish. About 1:4 and change
I have used a "left over" PK/A mount and modded it to fit the Topcor.
The mount has its own spring system.
I have also modded the mounts thickness a bit but not much was needed. Just parts of the edges.
Many other little things modded and most likely way to much. Now that I finally know what is needed to make it work i think I could make a much better version next time I find one of these lenses.
They are not cheap though.
In the process I also managed to break one of the blades. One of the two little nibbles fell off. I glewed another one on that I cut from a scrap lens. It works great but the new nibble didnt end up exactly right so now the aperture is almost rectangular instead of round. Will make an intersting bokeh I hope
Anywas.
its possible and thats great!
