Here is my little secret for removing lens fungus ... while I have never tried acetone, a "lady cream" (Monistat here in Canada, Miconazole Nitrate if you're a chemist) has worked wonders on tough fungus, even removing the fungal "traces" that alcohol (isoprop/kerosene) cleaning left behind.
I have even used it on a surface of a mirror lens, which is very delicate to work with.
So, in my opinion, monistat > acetone (as it's much gentler, look up how/where it gets used if in doubt
It smells nicer, too ... haha.
EDIT: This is what Wikipedia has to say about it. Apparently, the rinse agent for E-6 and CR-56 may be similar to the above cream:
Miconazole is an
imidazole antifungal agent, developed by
Janssen Pharmaceutica, commonly applied topically to the
skin or to
mucus membranes to cure
fungal infections. It works by inhibiting the synthesis of
ergosterol, a critical component of fungal
cell membranes. It can also be used against certain species of
Leishmania protozoa which are a type of unicellular
parasite that also contain ergosterol in their cell membranes. In addition to its antifungal and antiparasitic actions, it also has some limited
antibacterial properties. It is marketed in various formulations under various brand names.
Miconazole is also used in
Ektachrome film developing in the final rinse of the
Kodak E-6 process and similar Fuji CR-56 process, replacing
formaldehyde.
Fuji Hunt also includes miconazole as a final rinse additive in their formulation of the C-41RA rapid access color negative developing process.
Originally posted by Douglas_of_Sweden To the aceton?
Best thing to clean and kill the fungus would probably be a sulfuric acid solution, but that would definitely harm the coating, so aceton is probably a good compromise, and better against fungus than isopropanol (the usual main ingredients in most commercial lens cleaning liquids).
