I have been thinking about making something like this for years but never really got any bright ideas.
Couple of days ago i suddenly realised how I could do it so here it is.
I used a rubber ring ( for plumming perhaps? ) and a metalring + a pentax mount.
The metal ring is from some lens in my own little lens scrap-yard
It has the same outer diameter as the mount and would give a little extra space for the rubber ring to flex in.
I attached the ring with screws from the mount but those screws ended up inside the ring but with some tension. Some good glue and its not going anywere.
To preserve the flex I thought I could sew the rubber onto the ring so I drilled a lof of small 1.5mm holes in the ring and then sewed on the rubber thing.
Now my Bronica lens fits perfectly into that ring and flexes quite a bit.
I can reach infinity by pulling the lens towards me. Releaseing it will give a focusing distance of about 2 meter and pulling it further away gets me closer.
I can also adjust the lens in the rubber since its not glewed and get a close focusing of about 30cm.
Not ideal but for now im pleased. Infinity is the important part and I got that
I really would like to have something like a Bronica mount instead so that I could use other Bronica lenses or maybe some other Medium format lens?
Ideas would be much appreciated. My knowledge of medium formats is almost zero.
Here are some of the testshots I took yesterday and some of the lens and adapter.
All Tilt shots taken at f4. The shots of the lens are taken with my PK converted Topcor 35/2.8.
No PP except some levels in LR and a little bit sharpness. Bigger images if you click on one of them.
