Originally posted by Marc Sabatella i think you misunderstood my point. I said the image doesn't look as good at first (mostly on account of low contrast), but when you get down to it and after performing appropriate PP, it turns out there really *is* more resolution that there first appeared. See my samples posted here - while I'm not going to claim it a great lens (it clearly isn't), even it is capable of producing images you can't get with a shorter lens.
Sounds like I missed your point indeed. Sorry.
Anyway, I looked at a few of your shots, but I can't be sure at this size if your Samyang behaves like my Phoenix did. Can you post a 100% unprocessed crop? What I noticed with the Phoenix was a general softness around edges - like some blooming you would get from using a soft filter - unsharp mask would bring back some of the details, but I had to apply a lot of it. The colors also looked kind of washed out.
For reference,
here are a few test shots with associated 100% crops that I took when I got my Tokina - a week after returning the Phoenix. If your Samyang gets results that are close enough to those, then I guess I was just unlucky with my Phoenix sample and I should stop bad mouthing it, so let me know.
