08-24-2018, 01:57 PM   #961
GUB
GUB's Avatar
QuoteOriginally posted by marcusBMG Quote
I was surprised to see the rubinar wasn't listed GUB, so I listed it that's my lens in the pics. It's a nice one actually, with original case, filters etc. and cyrillic user manual/certificate.
The DoF calculations merely emphasise the tightness of the focus. The practical issue is seeing it, which IME I can't do well enough in my OVF's, only by using magnification in an EVF or on screen, and then millimetrically tickling the focus to try to nail it.
It just isn't easy with mirrors.
The rubinar for some reason is particularly ticklish, I find I'm to-ing and fro-ing a lot, and end up trying to land on a middle position (I wonder if there's a bit of slack in the helicoid - check - yes I think there is). The tamron is significantly better - more clear cut oof-in-oof as I move the focus.
I use Liveview and focus peaking. But the focus peaking is barely activated in the low contrast image and when you touch the lens to focus the movement upsets everything. It is interesting in the dof calculator when you push the Q out to 600metres where it should be for same magnification as K-1 the dof shoots out to over a hundred metres. That is probably the more correct scenario.
08-24-2018, 09:46 PM   #962
cooltouch's Avatar
I find the Pentax Q's "circle of confusion" of 0.005mm to be highly suspect, especially when compared to the other two.
08-24-2018, 10:45 PM   #963
GUB
GUB's Avatar
QuoteOriginally posted by cooltouch Quote
Yeah I was the same till I thought it through. The thing is this dof standard is based on an end product print of a given size. The Q sensor has to be magnified 6 times as much as the K-1 sensor to achieve this print size. .03 x 1 / 6 = .005
An extension of this is any lens on the Q will present with 1/6 of the resolution compared to itself on a FF. Hence why the Q is so hard on lenses.
11-19-2018, 08:28 AM - 3 Likes   #964
Sigma 600mm f8. Performs ok in spite of blemished mirror. X-post with sigma lens club. samsung NX20 from RAW.
11-19-2018, 08:57 AM   #965
redpit's Avatar
Nice images!
11-20-2018, 12:15 AM   #966
cooltouch's Avatar
Alright, Marcus -- looks like you've got one of the good ones. I've owned three Sigma 600s so far -- still own two of them. The best was the one I bought new in 1984 (and sold in 1989, dang it). The worst is a late model one in EOS mount i bought a few years ago. I bought another one a few months ago -- an early one, even earlier than my original 600. Its image quality is pretty good -- not as good as my Tamron 500, but not too far off. Contrast is low with this lens, and I think it's because of a fine coating of dust on the interior surfaces. I plan to dismantle the lens, thoroughly clean it, and test it again. I remain hopeful. I'm thinking about bringing my poor performer to our local pro camera repair shop and see if it can be recolimated to get rid of the double images it produces.
11-20-2018, 06:39 AM   #967
I guess so Michael - test pics of the neighbours chimney showed a tad sharper in fact than one of my tamron 500's. But boy the focus is ticklish. By way of comparison, a tele-tokina 600mm f8 I have been comparing it with focuses from 10m (cfd) to infinity in ~330 rotation. The sigma does the same in ~ 30 rotation!
I did moon pics with the tokina and my 31A+1.4x tc as well - results were all similar. I tend to find that with moon pics - it's more atmospherics etc differences between the lenses are evened out.
It's easy to open this lens up, just take off the rubber and peel off the tape to separate the focus so it comes off the helicoid (mark the point). The mirror is backsilvered like the tamrons so that dished any hope I had of being able to clean - the blemish (a peripheral ring of tarnishing/silvering deterioration) is permanent.
11-21-2018, 05:58 AM   #968
cooltouch's Avatar
Yeah, I've got the rubber ring off my focusing collar, just haven't taken things to the next step yet.
I'm puzzled by your comment about having only 30 degrees of focus rotation on your Sigma. My Sigmas' focusing ring rotation is almost as great as my Tamron's. The Tamron is almost 360 degrees, and my Sigma's is probably 340 degrees or so. I don't have one handy at the moment, but that's what I recall at least.
11-21-2018, 07:25 AM   #969
You can see from the pic how little rotation there is from 10m to infinity. Total focus throw is a bit over 180 so the 2m cfd is out of sight.
Mine seems to be a later example of this lens. This off-white one on ebay is, from your descriptions of the filter holder (metal), an early one. It looks the same re focus.
https://tinyurl.com/ydzbjk73
DMC-G1  Photo
11-21-2018, 10:16 PM   #970
cooltouch's Avatar
Okay, I follow you now. Most likely my Sigmas are the same way.
Regarding the white one at UK eBay, that is a later one. It's hard to see, but one of the middle photos just shows the black plastic tip of the filter holder. I have never seen an early Sigma 600 in any other color than gloss black. One interesting thing I discovered about my early Sigma is that it is noticeably smaller than the later ones. Probably about 4-5mm smaller in diameter compared to the later ones.
12-24-2018, 06:18 AM - 4 Likes   #971
Ash
Community Manager
Ash's Avatar
Time to add some photos from the stellar Tamron 500mm f/8:
Brolgas in Derby, West Australia
12-24-2018, 06:31 AM   #972
Rather similar in appearance to North American Sandhill Cranes. I guess all of the cranes dance, too.
12-24-2018, 09:30 AM - 1 Like   #973
Ash
Community Manager
Ash's Avatar
QuoteOriginally posted by goatsNdonkey Quote
Yes, they are a variety of crane, and they do the mating dance:
12-28-2018, 05:49 AM - 1 Like   #974
Ash
Community Manager
Ash's Avatar
Eagle in West Australia
Eagles at the water treatment plant, Derby:
03-07-2019, 05:17 AM   #975
Unsure if I am addressing the correct thread for this but I have a couple of questions.
I have just received my Tamron 55BB mirror lens, bought at auction with the fungus described so not disappointed to find lots of spores on the glass.
I have watched a video of how to dismantle the lens and it seems possible even for a clutz like me. (I dismantled my Pentax 80-320 and lost a collar into the lens body and am unable to retrieve it)
Is there any problems I should be aware of if I attempt this?
A few trial images show the lens to be sharper than my also recently acquired Makinon 500mm Mirror that looks in very good condition regarding the optics.
The little filter (with the legend normal) is also not optically perfect, the lens seems to work without it o do I need it?
adapter, bokeh, eclipse, extension, filter, flickr, flowers, k-30, k10d, lens, lenses, light, mirror, mirror lens, paul, pentax lens, pics, pm, post, screws, shot, shots, sigma, t-mount, thanks, thread, tube, view, weekend
The * lens club BrendanPK Pentax SLR Lens Discussion 56 08-13-2017 12:38 PM
Soviet Lens Club - MIR lens stevewig Lens Clubs 4 03-25-2016 02:50 AM
The *any and all* lens club yeatzee Lens Clubs 37 11-08-2012 04:50 PM
The 'Hey this lens has glass elements in it' Lens Club Igilligan Lens Clubs 50 11-14-2010 11:07 PM
The scratched lens club... TKH Pentax SLR Lens Discussion 4 01-29-2010 02:51 PM
All times are GMT -7. The time now is 07:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
