Originally posted by marcusBMG Another good one there
rmcnelly. Do you have any particular techniques or tricks for these shots?
If bringing the camera outside from an air conditioned or heated room, the lens needs to settle down to the outside temp. It’s a relatively small lens compared to telescopes, but it helps to let them settle to the outside temp.
This one was shot in the late afternoon and the sky was blue. Less contrast to deal with. Sometimes the atmosphere has too much temperature variations at different altitudes, and under those “seeing conditions” it’s much harder to get a good shot. Think of looking down a long asphalt highway on a really hot day, and how the image shimmers above it due to the heat. I suspect the atmosphere is more stable well after nightfall or during the day, less so at sunset or sunrise.
You’ll also get a better image when the moon is high up in the sky, when it’s low on the horizon you are looking through much more of the atmosphere, with more temperature fluctuations. Having the fixed display on the back of the Q makes it really tough to shoot straight overhead.
I have a magnifier attached to the back of the Q-S1 to help focus on the rear display, and use the camera’s zoom in on focus mode and have the focus highlight turned off. I just focus by what looks sharpest to my eye. Set the camera to the lowest iso, this was iso 100, 1/250 sec exposure using 2 sec shutter delay. I took about 10 shots and refocused every 2-3, and chose the best one to edit.
I used Lr to edit with a B&W Profile. I just play with all the sliders to get a black sky and brighten up the light areas. You can also adjust the color temperature and tint sliders as it will alter the brightness/contrast of the B&W image. I ended up not using much sharpening, whatever I tried looked bad. You can also adjust clarity and dehaze to get more detail, but it’s easy to go over board.
I’m certainly no expert at this, but hope it helps.
