Originally posted by BruceBanner If the SDM does fail, does that mean it can fall back onto using the Screw Drive instead? How does that happen if so? Does it need to be sent away, is it DIYable, is it performing worse as a Screw Drive etc?
DA* 60-250 can only screwdrive on very old bodies where SDM does not work, it cannot be converted to screwdrive (unlike 16-50 and 50-135) to work on more modern SDM compatible bodies. Basically you cannot use screwdrive on any bodies from a certain model dating back to 2007 or something I forget which exactly.
I've never used it on an old body like a *ist but you'll not be doing that anyway and neither will I
The SDM probably is OK on it, the 60-250 SDM fails much much less frequently than 16-50 or 50-135 where you have a decent chance of failure.
Using the lens more frequently apparently helps the SDM from failing, if you leave it for ages like a car the handbrake ceases up analogy.
I bought mine used from a camera shop with a 1 year guarantee cheaper than what they go for privately, however it is just about to run out, the lens is probably about 8 years old. A private seller is hardly going to offer you a 1 year guarantee.
I paid £359 UK for mine with 1 year warranty, lens was in fantastic condition with tripod foot, original caps and original Pentax zip case for 60-250...
Make sure you get the tripod foot!
