Originally posted by schnitzer79 its about time this thread got moving a little. great shots mtux. the M135/3.5 is a great lens. were these shots handheld? at the moment ive only got my 55-300 to pair with the DCR-150. however im thinking in purchasing the meyer optik 135mm f2.8 (or the super tak 135/3.5) in m42 mount. im assuming i wont have any problems pairing either of those with the raynox right?
Thanks.
Yes, all of them shot handheld, with on camera flash.
I guess you would be better served with the DA55-300, because then you can adjust the magnification with changing the zoom, but with a prime lens you can't!
And having a manual lens, if you want to use the on camera flash, like I did, you have no control on it's output, so you have to close down the aperture and ISO, which is another limitation I think.
I'm going to try the DCR-150 on my DA55-300 during this weekend to see how it will work with that. I will eventually end up trying it on all of my lenses. LOL.
