05-11-2010, 01:15 PM   #31
Voe
Voe's Avatar
Craig's Hut taken with Leica R 50mm Summicron:
Larger size: http://farm5.static.flickr.com/4022/4468176637_6215c50e40_o.jpg
Cheers,
Voe
05-12-2010, 05:40 AM - 1 Like   #32
This thread should be banned
Those pictures! They are COCAINE, MARIJUANA, POISON................
05-12-2010, 06:08 AM   #33
nulla's Avatar
Voe
that is an absolute briillant shot... sky is wonderful and the lighting in the foreground and fence is super.
Do you need a fourwheeler to get to Craigs Hut as I am off to Mansfield area later this month
Cheers
Neil
05-12-2010, 08:17 AM   #34
Voe
Voe's Avatar
Thanks Neil. Yes, you definitely need a 4WD to get there as the road is really coarse, narrow and quite long. Actually I went there with knumbnutz (Neil) on one of the weekends.
On that day it was very cloudy and there was just this time interval of less than a minute when the sun light lit the house and it is when I got this shot. I think it was worth the drive
05-13-2010, 03:08 AM   #35
Weiteres vom 50er Summi!
PENTAX K-7  Photo
05-15-2010, 02:40 PM   #36
aCIDfire's Avatar
great shot!
05-17-2010, 02:05 PM   #37
aCIDfire's Avatar
QuoteOriginally posted by Voe Quote
I bought one of those adapters from ebay and there are no issues except that it takes some fiddling to mount it on the camera. Apart from that it works as leitax.
Hi, please what do you mean "..some fiddling to mount it on the camera"? I found this one which looks pretty well manufactured:
Adapter for Leica R lens To Pentax P/K PK K10D K20D K-x - eBay (item 330417809928 end time May-25-10 02:49:28 PDT)
Do you think there is nothing to worry about buying this cheaper one? They look very similar so mounting on the lens should be also like leitax.
EDIT: There is also 5 holes on leitax one and 6 holes on the china one. On Leitax site there is written that the sixth one would interfere with the locking pin at the camera mount. Can someone
confirm that?
05-17-2010, 03:16 PM   #38
Voe
Voe's Avatar
With fiddling I meant that you need to move the lens in and out a little bit while screwing it into the camera. I now see that it's caused by the locking pin of the camera, which locks into the 6th hole. The solution is easy. All you have to do is keep it pressed while mounting/screwing the lens into the camera. I have the Leitax mount on my summicron and made in China one on my 28mm Elmarit and if I were you I would go with the made in China one as it is much cheaper and it's not such a big issue to keep the locking button presses.
05-18-2010, 01:49 PM   #39
Mechan1k's Avatar
I really shouldn't have look into this thread at all.
Amazing images indeed.
If I eventually get the funds ... I might actually look into these lenses.
Voe ... I have a different perspective of Craig's Hut framed on one of my walls ... mind you I ddin't take the image myself though.
05-18-2010, 02:40 PM   #40
aCIDfire's Avatar
Thank you Voe, I´d buy a china one it´s really much cheaper (on leitax prices is +16%VAT for EU customers). When you talk about that 6.th hole you have screws in all six holes? Is it right? Did you put some silicon grease under that ball that is recommended on leitax? Thx. Mark.
05-18-2010, 03:20 PM   #41
Piotr's Avatar
Summicron 90 is great bokeh master.
Pentax PENTAX K20D,Leitz 90mm f/2 Summicron-R
1/250s f/2 at 90.0mm iso100
1/125s f/2 at 90.0mm iso200
05-18-2010, 04:27 PM   #42
Voe
Voe's Avatar
QuoteOriginally posted by aCIDfire Quote
Yes there are screws in all the 6 holes (originally lens has 6 screws/holes). Instead of silicon I put white lithium grease (never wears or melts or leaks) where the ball is. Originally it had some regular grease, I believe what I did works better and for longer.
09-21-2010, 10:46 PM   #43
looks good guys, I just ordered a 135mm and a cheap converter for CanonEF I hope it fits well...I want that 28mm and the 90mm looks sweet...
10-12-2010, 09:11 PM   #44
xjjohnno's Avatar
Summilux 50 f1.4 with a Chinese version of the Leitax. One problem is I'm not getting infinity focus but the upside is I'm getting a lens allowing closer focussing. Stuff I've removed are the cams with shims, the mount and that inner black section on the mount, so everything before the aperture mechanism. I suppose I'll have to email those Leitax folk to see if anything else is in need of removing to get infinity focus.
Anyway some flower pics courtesy of the Summilux.
[IMGWIDELEFT]http://www.xjgarage.org/photos/october2010/slides/PICT2148.JPG[/IMGWIDELEFT]
[IMGWIDELEFT]http://www.xjgarage.org/photos/october2010/slides/PICT2134.JPG[/IMGWIDELEFT]
[IMGWIDELEFT]http://www.xjgarage.org/photos/october2010/slides/PICT2154.JPG[/IMGWIDELEFT]
[IMGWIDELEFT]http://www.xjgarage.org/photos/october2010/slides/PICT2189.JPG[/IMGWIDELEFT]
[IMGWIDELEFT]http://www.xjgarage.org/photos/october2010/slides/PICT2186.JPG[/IMGWIDELEFT]
10-12-2010, 10:38 PM   #45
that machine gun looking device you have is probably the coolest thing i’ve ever seen
50mm, 85mm, cambodia, center, colors, f/1.8, image, infinity, iso400, k1000, leica, leica lenses, lens, lenses, macro, method, nikkor, pentax, pentax lens, photos, pm, post, size, snow, summicron, thanks, thread, tri-x
The 'Hey this lens has glass elements in it' Lens Club Igilligan Lens Clubs 50 11-14-2010 11:07 PM
Nikon D3x vs Leica S2 lens mount jogiba Non-Pentax Cameras: Canon, Nikon, etc. 0 01-06-2010 12:10 PM
Leica R lens bigowl Pentax SLR Lens Discussion 7 07-05-2009 05:48 AM
All times are GMT -7. The time now is 12:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
