Originally posted by Jewelltrail Having shot with that very lens for a couple of years I can tell you it is not typical. I was always impressed with how well the 10-20 4-5.6 controlled flare, particularly when you consider the focal range. I am not someone to compose a shot with the Sun as the subject, but never had problems with flare in my shooting with this lens. That does not mean it will not flare--you must be mindful with the composition.
the composition is the key.. at certain angle toward sun this lens creates flare which more like hot spot in picture -same like its brother 8-16-
Originally posted by philbaum I think many folks shoot with a uv filter on this lens to protect the exposed element. I do use a filter and have seen this droplet kind of flare infrequently. Supposedly filters can contribute to flare problems but i have no before and after comparison shots.
Mind to start it (before and after comparison shots)?
Originally posted by Franki55 Na efektné zábery stačí niekedy iba statív a dobrý objekt, tu je pár záberov
z lacnej zábavy , vtedy ešte s K 100.
Love the shots..
Originally posted by jva59 first from Chania, Crete, the second from Koufanisia (view of Keros)
The first one seems like a great place to explore this lens.. prefer at blue/golden hours.
Originally posted by rob1234 Snowdonia
K100DS, 10-20 @ 20mm, 1/250th @ f/16
Doesn't always have to be set at 10mm!
Yes you're right.. at 10mm the great mountain will look much smaller. Nice pic
