Originally posted by philbaum I had a 3 image landscape hdr recently that had movement in 3 treetops due to wind. Photomatix's semi-manual method didn't fix it, so i made a virtual copy in LR of a single image, with a 1 EV step difference, input the vitual copy with the original into photomatix and came out with a good result. "semi-faux" hdr methods have a lot of advantages, IMO. Thank you for discussing it and i liked your hdr!
Thanks, and glad to hear your experience as well. It's amazing what you can do with one exposure and a little bit of work. I'm often confused when I see shots that are described as "nine exposure HDR," yet don't look like a scene that had a very high dynamic range to start out with. What do all the extra shots add? I have a feeling that there is a misapprehension that more shots always mean better HDR. Even if you're shootiing direct sunlight and full shadow, three shots will cover the range. (As an aside, I wonder if stacking images could yield better resolution using stacking software, but that's a different question.)
Something else that I learned (and most probably know this already): By default, ACR opens RAW images as 8-bits per channel. This discards some of the data from the original image when you finish your ACR editing and open in Photoshop. I've been trying to figure out how to get them to open as 16-bit images, which would preserve all of the information. There's what looks like a hyperlink at the bottom of the ACR window that lists the color space, color depth and resolution. If you click this, it brings up a dialog box that lets you set these parameters. I changed it to 16-bit.
I'm also experimenting with opening at the 25 mexapixel resolution, doing the Photoshop work, then downsampling. I'm not sure there's any benefit, though.
