Originally posted by axl I used tripod for very few shots. I'd say 9 out of 10 are handheld though.
Good thing is that at 10mm you only need f5.6 for DOF between
0.5m and infinity. So it leaves plenty of light for handholding.
BR
Peter
Peter - very nice shots, like the street flavor very much! I see you don't have much perspective distortion in your images - do you make a real effort to keep the lens horizontal to the ground or do you use software to correct?
BubblesT - I use a tripod 80% of the time, but for Peter's street shots, handheld makes much more sense.
REgards field curvature. Read this article by "Chambers" guy who said that to tell whether softness was due to field curvature, manually adjust the focus. If the mushiness goes away on the border but then appears in the center. its field curvature and all lens have it to some degree. Also, a slight amount of misfocus can drastically increase field curvature problems. I've wondered since i read the article, how many good lenses have been lost to unfounded accusations of softness when its just field curvature. His advice: get to know a specific lens and what are the problem situations for it. Real life testing is the best - almost an exact quote.
Phil
