Originally posted by missbrojensen I'm considering to buy this lens, and I want to know if you use any filters on it?
Yes, I use a regular (not a thin) UV filter on all my lenses. I also bought a LINEAR Polarizer (instead of a Circular Polarizer) for the Sigma 10-20mm as an experiment. Haven't had a chance to try the polarizer yet.
A note is in order about using the UV filter: I got the regular rather than the thin UV because I wanted to be able to keep the filter on all the time for protection of the lens element. The thin filters have no outside threads, as I understand it, so a lens cover wouldn't clamp on.
Also, and more importantly, as I first screwed on the UV I watched carefully and thought I saw the hint of contact between the lens element and the UV filter. I pulled off the filter, and knotted heavy duty sewing thread around the filter thread which is closest to the glass. I put on two wraps and used a toothpick to be sure the sewing thread was snug inside the screw thread closest to the glass. Then I screwed on the filter, watching with my hand lens as I snugged the filter in place. No contact between lens element and UV, because the sewing thread offers a barrier to over-tightening.
Sorry for the long-winded answer to your question, but I am concerned that some filters might contact the front elements of some of these wonderful Sigma lenses and thought I should describe what I did about it.
