Originally posted by Dan I find that I can get the sides and corners to be sharp at f/8 by focusing behind the central focus point. In most cases this requires focusing past infinity, which is possible with my copy (and I believe most copies) of the DA15. The center may end up just slightly less sharp, but not enough to matter. I set the aperture to f/8 and crank the focus ring all the way to the hard stop. This results in an image that is sharp across the frame.
Dan
A few days ago I took some images with the DA15. Some with very near subjects I wanted to be sharp as also the farest background. So I focused hyperfocal. In the end I wasn't quite happy since some distant trees at right hand side weren't as sharp as i hoped and also the horizon wasn't as sharp as I hoped.
So I thought I could try focus stacking with Helicon Focus for such a scenario and did it next day. I am quite happy with the result. The image without retouch of some double artifacts in the foreground - f8, 4 images stacked, one near infinity.
After this test I think that you not only can get sharpness from near foreground to infinity but you can also work against field curvature unsharpness of the DA15 by using focus stacking technic - if the circumstances allow this. Don't know if someone else did this test with the DA15.
