Originally posted by JimS_256
Is it worth getting a polarizer for this lens?
In my opinion, yes, unless these limitations give you pause:
- You may get a strong gradient effect in the sky under certain circumstances.
- A non-slim filter will intrude on the image circle (but not the central APS-C area normally occupied by the sensor; using Composition Adjust to its maximum potential will cause near-black corners).
I have not tried to penetrate reflective surfaces with my DA 15, so I cannot speak for this use case, but I assume it would work very well.
These four samples were all shot with a B&W CPL filter on the SMC DA 15 Ltd:
The gradient effect is quite subtle here.
Very little gradient effect, but extreme vignetting because I shifted the sensor all the way up to correct for converging lines. The upper left corner is not cropped and represents a worst-case scenario with my filter.
Strong gradient effect; camera pointing away from sun.
Very strong gradient effect; sun just below horizon on the left.
Edit: another reason to get one is that the 49 mm filter thread is shared with the first three M-series lenses in your signature, every other DA Limited, the DA 50-200, many FA primes, and every macro lens currently made by Pentax.
