This is a set of test pics of the Viv 17mm, with a comparison against the DAL 18-55mm, again click on the image to pull up the full sized ones. There is little difference in the field of view between this lens and the DAL 18-55mm at 18mm. This lens has a slightly wider FoV but it looks less to me than I would expect 17mm vs 18mm. And the comparison tends to corroborate the notion that modern wide angle lenses typically outdo vintage ones. Certainly f3.5 vs f3.5 I have to hand it to the DAL: most specifically more consistent across the frame. Here is the comparison, click to pull up the full sized 4928x3000px, 3MB image.
These images of the castle illustrate the level of distortion, with again comparison against the DAL. Results are again similar, overall both results please with good resolution and detail. The Viv sharpens up a just bit more at f8 and f11 - the typical f stops to use with a wide angle - mainly off centre. One point on which the viv scores is it has less/less obvious fringing than the DAL.
