11-02-2014, 09:58 AM   #1141
akptc's Avatar
QuoteOriginally posted by Auzzie-Phoenix Quote
Actually I might have an explanation for this. I have the sigma 75-300mm f/4-5.6 DL autofocus zoom and it only works manual as well, but I have noticed something about it. Setting aperture ring to auto and having the camera in AF.S it will keep track of the focal length when you adjust the slide but that's about all the data it transmits. The mount doesn't seem to be set up properly. I have to hold the release button and further tighten mine just to get the camera to register that the lens is there, else I get the blank F-- and no reaction. Due to the incorrect nature of the mount, I believe that this causes the AF to not function both by not having the data pins in the correct place, or the screw drive for the af adjuster in the correct spot as well. Though this behavior causes me no issues since I shoot manually regardless. Mind you i have no clue if this is actually the case with your lens.
Interesting. I tried the lens on my K5 today, the camera did not ask for focal length and the lens behaved like an "A" lens; however, I was able to dial-in 2.8 via the camera while the max aperture possible is of course 4.0. Very odd.
11-02-2014, 11:23 AM   #1142
QuoteOriginally posted by akptc Quote
Yes, I can dial-in an aperture on mine in manual, and in auto it goes by metering, so it does act like an A series.
11-02-2014, 03:00 PM   #1143
EJMzagsfan's Avatar
17-50 2.8, it was raining and there were drops on the front element, but it doesn't bother me all that much.
11-02-2014, 04:35 PM   #1144
I actually need to retract this. While the camera doesn't report an F stop value, the autofocus has started working without doing the "overshift" maneuver. I believe my issue with the autofocus not functioning was due to not having the settings for manual lenses enabled in the k-50. The last time I had used the lens was prior to obtaining my smc pentax-m 28mm f/2.8 prime, so I hadn't enabled aperture ring mode 2 on page 4 of the custom menu, nor had I set the green button for stop down metering yet.
However, what this means is that your zoom might still work with autofocus. Just enable the manual aperture setting in custom menu, as well as green for stop down meter in manual, then set camera to af.s with the 70-210mm zoom on. Since the camera doesn't register an f-stop number, you'll have to use that manually instead of setting the aperture ring on the lens to the A setting. I used my AF for quite a bit today playing with the camera handheld, even got some decent moon shots without the tripod. Although with the weather being colder and having to focus the heavier lens, it sure did eat away at the battery quickly.
11-02-2014, 07:19 PM   #1145
Taken at the lake today with the 75-300mm DL zoom (with the now apparently working autofocus). Apparently in EXIF the lens thinks it's an 18-200mm DC F/3.5-6.3? Must use same logic chip or something. Either that or it was taken apart and frankensteined... I don't know either way, but it sure is a nice lens.
11-03-2014, 04:33 PM - 1 Like   #1146
Sigma 75-200 3.8 AF @4
11-04-2014, 12:26 AM   #1147
Digitalis's Avatar
Pentax K5IIs - Sigma 8-16mm f/4.5-5.6 EX DC @ 8mm f/8 ISO1250
11-04-2014, 02:23 AM   #1148
Pablom's Avatar
Sigma 24mm f/2.8 and Velvia 100
0011
by Pablo Margulies, on Flickr
11-04-2014, 05:02 AM   #1149
ivanvernon's Avatar
QuoteOriginally posted by Cabessius Quote
Sigma Super-wide II 24mm f2.8
1/100s
f8
ISO 100
Very nice, but what is this structure? It reminds me of some of the ancient architecture seen in India.
11-04-2014, 05:15 AM   #1150
Sigma 70 – 300 APO DG Macro
This consumer zoom gets usually quite bad reviews. However I like my copy – at 10 MP sensor it can be sharp at 100% crop, so If you do not need really fast AF this can be one of the solutions.
Last photo was made using Pentax Q at 220 mm/5.6.
11-04-2014, 05:53 AM   #1151
ivanvernon's Avatar
Sigma Zoom-Master 35-70 mm f 2.8-4.0 multi-coated
I picked up this old Sigma manual focus zoom lens on an older model film camera, and never tried it out until this morning. Here are a few shots on the K-7 in early morning light (around 7:00 a.m. EST). The lens has an A setting, so works on all K-7 modes, and these shots were Av or manual. I would appreciate any thoughts/reactions anyone would care to offer on lens performance, not composition or topic. These are right out of the camera, no PhotoShopping. I have not been able to find any reviews of this old film lens.
ADDED NOTE: EXIF shows 50 mm FL for all three photos, but these readings are incorrect. The pumpkin, first shot, is more like 35 or 40 mm, and the last shot of my wife's greenhouse is 70 mm. The middle shot of the wishing well is intermediate, probably somewhere around 50 mm.
PENTAX K-7  Photo
PENTAX K-7  Photo
PENTAX K-7  Photo
Last edited by ivanvernon; 11-04-2014 at 05:59 AM. Reason: To add focal length information given incorrectly in EXIF.
11-04-2014, 06:35 AM   #1152
Digitalis's Avatar
Pentax K5IIs - Sigma 180mm f/3.5 APO EX @ f/5.6 1/500th ISO 80
11-04-2014, 09:43 AM   #1153
more with the 75-200 F3.8 AF
11-04-2014, 09:53 AM   #1154
Jonathan Mac's Avatar
QuoteOriginally posted by ivanvernon Quote
Soft and low contrast. Based on these photos I'd get rid of it.
11-04-2014, 07:39 PM   #1155
Weevil's Avatar
Sigma 180mm macro f3.5
Hosta sp. (Abiqua Blue Crinkles)
by Curculion, on Flickr
address, birds, bread, club, colors, dg, email, f4, flickr, flower, idaho, images, k-3, lens, lenses, macro, nov, pentax lens, post, ruins, sage, shot, sigma, sigma lens, sw, texas, thanks, time, usa
300mm plus Lens Club: discuss your long lenses cooldude14es Lens Clubs 34589 13 Minutes Ago 01:42 AM
Soviet lenses club Voe Lens Clubs 3976 1 Hour Ago 12:40 AM
SIGMA 10-20mm CLUB Jewelltrail Lens Clubs 3836 3 Days Ago 08:19 AM
SIGMA 8-16mm CLUB ManhattanProject Lens Clubs 837 12-17-2019 02:29 AM
The 'Hey this lens has glass elements in it' Lens Club Igilligan Lens Clubs 50 11-14-2010 11:07 PM
All times are GMT -7. The time now is 01:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
