Originally posted by Pentaxor thank you for the comparisons Lowell. it might be a bother to you to do the comparisons but it's good to see some tests that show the differences between 135mm lenses.
anyway, do you have any close-up or midrange shots with variable and comparable apertures that would show a much clearer distinction between lenses that would show the overall IQ variations between the 135mm lenses?
It's no bother on the testing, I had time last evening while my son was at guitar lessons. Ptoblem was, lighting on the street was not the greatest.
There aer a couple of things I really want to do,
one set of shots, at a distance of about 1.8-2 meters, so that it is within the close focus range of all the lenses, wide open, F4, and F8. This should show any variances in bokeh due to aperture shape and close focus sharpness nicely.
a second is at a distance of maybe 5-8 meters.similar to the shot of my daughter, but with more colour, in daylight, again at the 3 apertures mentioned
this will really compare the lens at the distance intended, i.e. outdoor portrait which is what a 135 really is for.
My impression is that the rikenon seems better close up the tele lentar better at 5-8 meters, but that is just an impression at this point, not a hard fact.
I prefer natural lighting, but I might be inclined to put my AF540 FGZ and re-learn auto flash, to see how each performs with flash lighting(or if I get really lazy, I can use my *istD and ttl flash
