Originally posted by RBellavance AFAIK, you cannot use HHS and wireless flash with the built-in (aka pop-up) flash. You need *two* external flashes for this to work: 1 as "master" on the camera (in HSS mode), and another as P-TTL slave (also in HSS mode, I guess).
Yes I found out that i could only use HSS with K-7 and AF540 with mounted on the hotshoe. It wouldn't work on wireless!! (seemed to contradict the AF540FGZ manual)?
I wonder uf you could use HSS with the flash tethered on the sync cable? assume so, can it do HSS above 1/180?
Originally posted by ll_coffee_lP I'm not looking to use the pop up flash at all. Off camera flash only.
I'd rather dig my eyes out with a dull plastic spoon than use the on-board flash
c[_]
BTW you can set the onboard flash to only control fire, meaning it doesnt show up in the actual exposure. (its set C-31 to "2" in menu on your K-7)
Or as RBellavance says have 2 "proper flashes" with HSS. Mounted one on "master"(if you want it in exposure) or as "control" (if you dont want it to be in the exposure) and remote flash you want to expose as "slave".
In "master" & remote "slave" both will fire in the exposure
In "control" & remote "slave" only the remote will be in the exposure (I think thats what you originally wanted?
err I think thats right...
Reason: clarification
