Originally posted by hoanpham Very interesting thread.
I have a few questions:
When you adjust the trimpot, did you have camera body measurement in spot or center weight or average?
I guess that you have a histogram of manual power as reference. As for reference, is it 1/2 power? I am consider +1 as full power.
I haven't experimented with the K-5, but my experience with the K10 and K20 was that spot/CW/matrix setting on the camera is ignored when taking flash pictures.
+1 FEC is NOT full power - it's just one stop overexposed if the flash is adjusted correctly. Full power is when the flash is set to Manual and 1/1 power - this trimpot does not adjust that behavior in any way, shape, or form.
Really in my case after I started adjusting, I took a screwdriver around with me and frequently adjusted it until I was happy with where things were landing. Mine may, if anything, be dialed a bit "hot", partly because we have an FEC range of -2 to +1, so there is more room for dialing down a flash that overexposes.
(Previously, my 540 would routinely underexpose even with +1 FEC dialed in.)
