Originally posted by roy will,
I'm pretty sure you can trigger the flash wirelessly with your setup. why spend $100+ if you don't need it..
You are quite right, Roy, I can trigger the flash by popping up the built-in flash, setting everything to wireless mode, and letting the built-in flash sent out a burst that triggers the detached unit (the 540FGZ). I have used this effectively already and feel comfortable with it.
But there are two problems with this form of wireless (where one flash triggers the other -- I'm
not talking about using radio signals like with a Pocket Wizard). First, if you're shooting an event where there are other photographers (say, a wedding, but I've had this problem elsewhere), someone else's flash may trigger my flash. Second, light-based wireless doesn't work real well if you're using the detached unit for fill flash outside in fairly bright ambient light.
I believe that a cord will eliminate both of those problems. I do not want to bother with Pocket Wizards at a wedding or First Communion or similar event. Just too much hassle for me!
Quote: i don't like the bracket you are getting. i think you'd like one that can keep the flash above the lens whether it's in portrait or landscape mode.
Good thought and one I have wondered about myself. I'm not sure, but it
looks to me as the Bogen Manfrotto will indeed pivot on two axes so that you can get the flash above the lens even in portrait mode. I've studied
this photo of the unit and it seems to me that the main "mast" can be turned down so that it's parallel to the base of the bracket. Several user reviews of the product mention that it's very adjustable.
What I really like about this unit is that it looks like you can really get that flash pretty far from the lens -- either high up, or hanging off to the side, or somewhere in between.
Will
