I have never used a flash bracket when shooting events in the past, but now I'm reconsidering. More experienced event photographers I've talked to seem to fall into two schools: one says a bracket is really useful, the other says the bracket isn't useful enough to offset the fact that it's a hassle to deal with. Which do you think is right? With the Pentax 540FGZ flash unit attached to the camera by the hot shoe, I haven't felt particularly handicapped. I don't have problems with red eye. I bounce the flash when appropriate and possible and the results seem generally good. What exactly
would I gain if I were to move the flash off the camera, up a few inches and over to the left?
I myself can see, or rather I can imagine, two main advantages to using a bracket. First, with the detachable unit on the bracket rather than on the camera, I could either use the camera's built-in flash or (if I owned one) use a second flash unit on the camera -- thus generating more light, if that really mattered. But how often does it really matter?
The other advantage I can see is that the bracket makes that "I'm the Pro" statement. Nice complement to the hand grip. I'm only half joking about this being an advantage.
Am I missing something else? Would I lead a better, fuller life as a photographer if I started shooting with the flash off the camera and on a bracket? And if I would, what bracket would you recommend? I would be grateful for budget-minded recommendations here, although if you want to explain to me why the $100 model you recommend is twice as good as the $50 model I would rather buy, I'm all ears.
Oh, one last question. If the camera has a bracket attached, do you have to take the bracket
off to mount it on a tripod? I guess you must have to, but I'm not sure.
Thanks in advance.
Will
