Originally posted by jake14mw I knew that Nikon had Pentax bested regarding the fact that in the Nikon system the power of each flash can be controlled from the camera itself, but I thought there was a way to set relative power levels on the Pentax flashes themselves. Sounds like maybe the only thing that could be done is to use the individual +- compensation on the flashes themselves? Maybe do a + on the one that you want as your main, and a - on the fill?
There are two power output adjustments on the Pentax flashes when used wirelessly, FEC and a power ratio. FEC raises and lowers the power in stops. I don't really understand how the power ratio works. Either the flash knows about the multiple flashes and determines the over scene with the ratio in mind, or the flashes are independent and the power ratio simply overrides what the camera sends it.
You can also use the flashes in manual with wireless, (uses wireless channels and isn't a dumb optical slave), and set the output from 1/1 to 1/32, maybe lower on 540 but I don't own one so I don't know. There is also Auto flash available in wireless.
All in all the Pentax flashes are pretty full featured and offer a lot features other flashes don't, but they do require you to go to each flash to set those features up.
Thank you
Russell
