Originally posted by Adam Perhaps you missed this accessory:
PENTAX TR Power Pack 3 - Pentax Accessory Review Database - Flashes, Grips, Camera Bags
Sounds like just what you're looking for- except that it still uses regular C batteries. Should still easily last for an entire day, though.
The AF540 normally takes 4 AA batteries, which is approximately 10800 mAh (2700x4). The TR power pack will have about 48000 (6x8000) mAh with alkaline batteries, so you're looking at at least 4 times as much power.
Um, I may be wrong, but those batteries are connected in series not parallel, so the Ah do not add together, but supply a higher voltage at the individual battery Ah. That would make the C batteries provide 8000mAh/2700mAh=2.96 or about 3 times as much power, giving about 3 times the operating time, so C batteries will need to be changed at least twice in 7 hours given AAs last 1 hour or less.
Also, OP already knows about the TR-3, but considers it 'expensive'.
@amoringello, your idea of 'fake' battery pack will work as long as the voltage is correct. For 4 AA batteries in series that is 4.8-6 volts, so you need a 6 volt large battery, not a 12 volt. Then there is the problem of passing the wires through the flash battery cover. I suggest that changing the AAs in the three flashes every hour or so is less effort than rigging up a homebrew alternative, ymmv.
