Hey all, I've been thinking pretty hard on getting a flash to help out my indoor people shots, as while taping aluminum foil to my camera is a workable solution to use my popup flash with, it does have some pretty severe limitations, such as working distance, room size, etc. So I've found some good/decent local deals as well as the more conventional options, and now I'm looking for some help to decide which'd be best for me:
Vivitar 730 AF P $65
Pentax AF-330 FTZ $30
Pentax AF-400 FTZ $70-80
These're the local deals, and I'd pounce, but after some reading, I found out that these're TTL flashes, which won't work or something with my k-x? Enlighten me if otherwise; I'm pretty noob with this. But yeah, except for the 330, I love that they can rotate/swivel - bounce flash is about the only thing I really know how to do. And I guess fill flash, ish.
And then my other choice would be the Metz 48, or its replacement the Metz 50 (?). Obviously, it's much more expensive, but it has P-TTL flash.
Which leads into my other question - how do I meter for bounce flashing? Or does P-TTL/flashes with auto modes do it for me? Also, I've heard some talk about how auto >>>>> P-ttl in that people have had pretty inconsistent results with P-TTL metering, what's the deal with that?
