the Metz 48 works perfectly with Km/Kx, BUT: k-5 p-TTL is inconsistent with the unit.
My second (replacement for the stained sensor body) K5 has the same inconsistent p-TTL metering as the first with my one year old Metz 48 which works perfectly with Km and Kx bodies. Metz guys say that they are working on the issue jointly with Pentax and that Pentax admitted that it was not Metz's fault.
I quote the response from Metz:
Dear Mr Kriviniouk,
Thank you for your e-mail
Please be informed, the digital camera "Pentax K-5" is intensively tested yet by our company's developing department (laboratory) with original flash units from Pentax, e.g. "Pentax AF-540FGZ", and also with the flash units of our product range. The digital camera "Pentax K-5" is also intensively tested yet with the flash unit "mecablitz 48 AF-1 P digital".
In principle, in full automatic "P-TTL flash control mode" flash unit's flash light output intensity is only determined by the camera (e.g. "Pentax K-5") and not by any external flash unit in camera's hot shoe. Full automatic P-TTL flash control flash light output intensity is not determined by external original Pentax flash units and not determined by external Metz flash units in camera's hot shoe.
The engineers of our company's developing department (laboratory) found out that there are really problems with the full automatic "Pentax P-TTL flash light control" with the camera "Pentax K-5" and any external flash units. However, these problems are also known by running the camera "Pentax K-5" with original Pentax flash units, e.g. "Pentax AF-540FGZ". For this reason, the mentioned problems in full automatic "Pentax P-TTL flash light control" are caused by the camera "Pentax K-5" and not by any external flash units.
Please be informed, many users of the camera "Pentax K-5" and even original Pentax flash units, e.g. "Pentax AF-540FGZ", also complain about these problems with "Pentax P-TTL flash light control".
To have these problems with full automatic "Pentax P-TTL flash light control" solved, in first line the camera's "Pentax K-5" firmware needs an update. We do not recommend any flash unit for this type of camera until camera's firmware problems are solved. For this reason the digital camera "Pentax K-5" is also not mentioned in the recommendations on our homepage:
http://www.metz.de/en/photo-electron...endations.html
We regret to have no other information for you and remain
With kind regards
Wolfgang Becker
Technical Support
_____________________________________________
Metz-Werke GmbH & Co KG
Ohmstra?e 55, D-90513 Zirndorf
eMail:
wolfgang.becker@metz.de
Internet:
Home: Metz
Sitz Zirndorf, AG F?rth HRA 5766
phG: Metz-Werke Verwaltungs-GmbH
Sitz Zirndorf, AG F?rth HRB 3283
Gesch?ftsf?hrung: Dr. Norbert Kotzbauer, Manfred Billenstein
USt-IdNr.: DE132748642
