Originally posted by scorpioh May I check if there will be motion blurring and handshake when you use a slow shutter like 1/20. My experience tells me that 1/20 is slow enough for these to creep in in flashless photography but somehow it doesn't quite work the same way when flash is used? What's the reason behind? The flash freezes the motion?
Being very non technical, i feel that using slow shutterspeed with flash does help to prevent blur, to some mild extent that i cant explain.
I always use slow speeds from 1/15 to 1/80 when im indoors shoting candids, with flash. And motion blur is clearly not that apparent then, as when i dont use flash.
Maybe its a very thin line and very dependent on how people move.....
The point is still to blend in as much ambient light as possible to get a nice exposure.
Using higher ISO also helps, i tend to be around 400-800.
