Originally posted by newarts You can use a little aluminum foil to trick the camera into thinking the lens is a A type. To do this you must short circuit the indented contact on the camera side of the lens mount.
When you are successful, the e-wheel will work and the auto-flash will work.
Dave
Thanks, i tried that (locating the "A" - Contact on the body mount, and putting some aluminium foil on the contact, fastening it with normal transperent tape, but with the manual macro lens on the camera it still does not "think" it is an "A"- Lens.
Those of you that have done something like this before, how much aluminum foil did you put on the "A" contact (it is a bit more hidden on the K7), and how (with what substance, or tape) ? did you glue it to the mount?
Thanks
