10-13-2010, 09:06 AM   #1
AF360 Problem
I have had a AF360 flash for quite some time but have never used it much as most of my photography is done outside. I used it last week at a friends wedding and it did not preflash. It is my understanding that in PTTL it should fire a preflash before the main flash fires. When I tested it out at home the night before the wedding it did preflash. I have tried it several more times since and still no preflash. Is my flash screwed up or am I doing something wrong?
10-13-2010, 11:40 AM   #2
The pre-flash occurs just before the mirror goes up. I think there's only 1/50 sec between the pre-flash strobe and the main strobe. Most people can't tell the two strobes apart. They appear as only one (note that the frames in the movie are 1/24 or 1/30 sec apart).
To see the pre-flash, put your flash in p-TTL mode and your camera body in 2 sec delay self timer. When you hit the shutter release, these happen in order:
- Pre-flash strobe.
- Mirror going up.
- (After 2 sec) Shutter opening.
- Main strobe.
10-14-2010, 02:34 PM   #3
Thanks SOldBear, I'll check that out tonight. It confused me because when I tried it the night before the wedding, there was two distinct flashes with the first one seeming less powerful. The flash also made more noise when the first flash fired. Weird!
10-23-2010, 11:03 AM   #4
QuoteOriginally posted by fiveo Quote
I have actually noticed the same. When I first put the AF360 on my KX and set it to PTTL there were two distinct flashes. Later at home with the same settings, I could only see one flash.
Read the manual twice, but it does not clearly state what setting to use on the camera for PTTL. When I tried P, Av, and M the camera seems to select slow shutter speeds, 1/15 or 1/30. If I use Tv and set it to 1/125 it always selects f4.
af360, flash, lighting, photo studio, preflash, strobist, wedding
second curtain sync problem K10D + AF360 cactusmelba Pentax DSLR Discussion 8 04-26-2010 01:22 AM
problem with AF360 battery compartment Shaloot! Flashes, Lighting, and Studio 1 12-26-2008 02:14 PM
AF360 Problem LScrabeck Flashes, Lighting, and Studio 0 11-29-2008 11:41 PM
AF360 cactus v2 k100d problem rapphaelray Flashes, Lighting, and Studio 16 06-01-2008 08:34 PM
Need help with AF360! photodad Flashes, Lighting, and Studio 9 01-15-2007 08:55 AM
All times are GMT -7. The time now is 02:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
