You could still use this directly but for it to be usable, you have to get the QDA-P module for the flash itself 'coz the other modules wouldn't work or will always cause it to fire full power.
The QDA-P module is an auto-thyristor module when set to "auto" and also has settings that will let you set the flash output to less power to full power output for full manual control.
If you really want to be safe then you can also attach this via a PC sync if your camera has that or has an attachment for the hot shoe that provides a pc sync outlet..if not, you can use wireless triggers and use this as your second flash for highlight fill or background fill..etc.
There are the radio wireless flash triggers or the old optical slave flash triggers.
If in doubt, ask more from other forums members.
