Possible problem with Metz 48
I accidently dropped my Metz 48 on the floor which broke the plastic hot shoe but I was able to fix it with some plastic glue!
While testing if the strobe was functioning properly, i noted something that i havent noticed before (using TTL connected to a K7). When I set my lens to 18mm, the display of the Metz say 70mm, if I adjust the lens to 20mm the Metz says 35mm. As you can see the flash display does not match what the lens is set to.
From what I can tell the test shots that I made are exposed correctly, but I'm worried that the flash may be damaged.
Is it normal for the strobe to display those values?
