Funny how a month old thread will resurface. I had decided to get a *istD and it arrived today. I did some test shooting with the "new" camera and the AF400T (which for those that don't know it was the older handle mounted pro flash for LX/645/6x7). Works just fine as far as I can see so far.
It was cheaper than a new AF540 and the camera came with a grip! I have used the AF400T on the k10D but the issue was that I wanted it for weddings. I can adjust the flash/camera to take a shot when the time permits between shots but anyone that's shot a wedding knows that you have no time to make adjustments or test shots at weddings. The *istD is perfect and the bonus is it's better in low light in the church when a flash isn't allowed. The other nice thing is the camera is basically laid out the same as the K10D. So no having to make a "brain switch" when moving quickly and changing bodies.
As for why TTL doesn't work vs P-TTL. Well the main reason is that Pentax and other brands decided to move away from the TTL system. It read off the film plane and the sensor is much more reflective so they felt the results were inconsistant. I can't say for all models (the *istD does) but I certain that all the D series cameras had an additional sensor in the mirror bucket that was used for the TTL flash. To save costs they dropped that sensor in the newer K series.
There was a good thread discussing some of this here. Just ignore the last idiot (RiceHigh):
https://www.pentaxforums.com/forums/pentax-dslr-discussion/13886-ttl-p-ttl-flash.html
