Originally posted by ekim89 Ok, so after doing much research and such about a cheap flash unit for my K-x, there are some questions that I need answered. I am looking at a Sunpak Auto 422D Thyristor or Sunpak Auto388. The more straightforward the answer, the better because my head is spinning from reading a whole bunch of information.
Among the "old" flash units, the Sunpak 4xxD series offers the most bang the buck. They are compact, powerful (for their sizes), can swivel and bounce, have auto mode with 3 settings, have manual mode with variable ratio settings, and probably most importantly, have low trigger voltage.
I'm not familiar with the Sunpak 388, but I think it is one step below the 4xxD series. I think the biggest disadvantage of the 3xx series compared to the 4xxD is that the 3xx series does not have "dedicated" module. The "dedication" really does not matter for the current DSLRs, but the removable module (with the light sensor) gives you some flexibility in using the flash off camera (more on this later).
Originally posted by ekim89 1) Is it safe to use on my K-x DSLR, and does anyone happen to know the max. allowable voltage range that can be used on the K-x? (I understand that I would need to test the voltage of the flash to be safe and I read the Botzilla Photo Strobe Trigger Voltages for both the Auto388 and 422D)
You will NOT find the specs of allowable trigger voltage from Pentax, or any other camera makers (except Ricoh specifically says 20V in the manual). I use 24V as the limit.
The 4xxD series has trigger voltage around 6 - 7V so it is safe for Pentax DSLRs.
Originally posted by ekim89 2) This whole module/hotshoe business, which one will work and what should I look for when buying on eBay?
I noticed my search on eBay returned things such as "Nikon with Nikon NE-2D head"
If the module has the standard foot that fits in the camera's hotshoe, you're OK. Except for the sync signal (for which all modules are the same), there is no communication between the flash and the camera. I have several different modules: for Ricoh, for Nikon (yes, the NE-2D), for Pentax, and for Minolta. I use them exchangeably for my K10Ds and K7, even with my Canon G5 and Ricoh GX200 without any problem.
When the camera is in Av mode (maybe in some other modes as well), the Pentax modules (PT-1D and PT-2D) will set the camera's to sync speed (normally around 1/60 sec depending on the lens). I myself don't use this feature. I just set the camera in M mode and choose the shutter speed myself.
The only modules you want to avoid are the ones that fit on top of the rewind crank for Nikon and for Olympus. They don't have the standard foot and thus don't fit the camera's hotshoe. But if the flash comes with it, it's OK. You can buy modules separately (e.g. from KEH).
Originally posted by ekim89 3) In the picture at the bottom of
this listing, the module on there says for
CONTAX 137MD/139 QUARTZ MODULE and all other hot shoe mount regular cameras, would that mount work for the K-x?
Yes. It will work with your K-x. I would buy that particular one if I needed a flash right now.
Originally posted by ekim89 4) Will the flash unit allow me to use a radio trigger?
Yes. Sunpak flashes work fine with my Yongnuo RF-602.
Originally posted by ekim89 If you can, please help the newbie that doesn't understand the aspects of flashes and if given a choice between the 422D and Auto388, which would you choose and why? Thank you!
As stated, I don't know much about the 388. But I'd choose the 422D. Here's the reason:
You can buy Sunpak dedicated extension cord (I have the EXT-08, about $10 from KEH). The extension cord will be between the module (which is attached to the camera's hotshoe) and the flash unit. No matter where you point the flash, the light sensor always faces forward. This is helpful in many situations.
Here are some photos of my DX36 setup (DX36 is the European name of 444D, which is very similar to the 422D):
