BEFORE ATTACHING THE FLASH TO THE CAMERA: please check the flash's trigger voltage. Have the flash fully charge, measure the voltage from the center pin of the flash's foot (positive) and one of the contacts on the sides of the flash's foot (ground). If the reading is 6V or less, the flash is definitely safe. If more than 6V, it's "your call." I use 24V as the limit. Do a search for "flash trigger voltage" if you need more info.
Originally posted by Adam It should work, but you'll have to meter manually and sync at 1/60s most likely. Definitely not convenient...but it'll work!
Uhmmm......
I think it will sync at any speed 1/180 sec and lower. The sync speed is determined by the camera, not by the flash (unless for ancient tungsten flash bulbs).
Also, it looks like in addition to manual, the Focal DA-2000 has auto mode (using the flash's light sensor).
For auto mode:
- Set the flash to 'auto' and the camera to 'M'.
- Set camera shutter speed to 1/180 (X speed) or lower.
- Set ISO on the flash, note the aperture pointed to by the flash (e.g. f/4 at ISO 200, or f/5.6 at ISO 400). On the camera, set the ISO and the aperture to the same values as on the flash.
- Fire some test shots.
