Originally posted by saladfunky Thanks for that, so I have the option of auto or manual modes left on the cobra D650. Has anyone else used this combination successfully? K10D and cobra D650? or similar? Other question is how would a modern flash work on the K10D? Is TTL now old school?
thanks, I'm learning alot
Chris
Old-fashioned auto mode ought to work just fine for you with that unit, possibly with a little correction by now, ...Pentax digitals since some years ago (One of the *ist D-models? Not sure.) have a newer TTL flash metering protocol called P-ttl, which is actually through-the-lens, but based on measuring a little pre-strobing of the tube in the instant before the actual shutter opens, rather than shutting down the actual flash duration during the exposure like 'true' ttl.
It's not a popular thing about this system, (particularly when it comes to how long it's taken for there to be very many fully-compatible automated flash options: I'm kind of hoping future models will find a way to work the old true TTL option back in somehow: there are advantages to it. ) but a newer P-ttl flash will work OK, if you get hold of one of those too.
If that's making sense: I'm up pretty early this morning.
Anyway, the old 'auto' flash just has a little 'electric eye' on the flash itself which tells the flash when to cut its own duration off: barring anything fooling it or exceeding range limits, it gives light to deliver proper exposure at the f-stop selected.
(True TTL essentially does the same thing, but the 'electric eye' is in the camera, so it can be more direct and precise. )
I like the old 'auto' just fine, though, actually: it's a pretty convenient way to balance the ambient light and what the flash adds. You just tend to get fewer choices of aperture ranges.
