Originally posted by NicoleAu Thanks Class A. When I get them I'll experiment and see how I go. After that I'll decide whether I need to splash out on one or not. I plan on using the units for portraiture outdoors.
I just did this scene tonight with 3 flashes, a Metz48, a Yongnuo560, a Yongnuo460 all in manual mode. I've been doing these little scenes to learn how to use and set up the flashes. In this case, i used one flash to light my face, and put 2 more in the tunnel to light it up, its quite large.
Setting up the flashes went pretty quickly, the biggest problem i've been having is getting all the radio triggers to work. If i don't go out with fresh batteries each time, I'll have problems and have to troubleshoot. Once i have fresh batteries, they work every time - unless they are practically sitting on one another.
You don't need a flash meter, imo, but more usefully, get a quality 8-battery charger like the maha powerex which individually will charge each battery to its maximum. plus it will top off any batteries that just down a little. Also, this charger will charge a mix of both NIMH AA and AAA at the same time. From now on, i'm not leaving any batteries in the triggers till next time, but recharging them all and putting them in a bag for use. My flashes are working fine and don't need any replacement batteries at the worksite. Its the triggers that failing to work with AAA unless they are fully charged. I understand these rf triggers have a range of 100 meters. maybe that explains why they are so demanding. Other than the battery issue, they work fine
