Originally posted by Class A +1
Andi Lo, if you get one of these, let us know whether it worked. As Autodidact said, it should work. The only reason why it might not could be that the cables swap around contacts, but don't see why they should do that.
Note that your first one is a male to female. You'd have to add one of the supplied cables to connect it to the transceiver.
I'd get a male to male and your last one seems to be the best choice because of the flexible length and the 90° bend at the camera end.
I'm trying to guess why people are using cables. I think the one application is:
a. Some of the strobist information shows velcroing the rf trigger to the side of the flash with a short cable going to the trigger. I think this is so that the flash will still be centered within an umbrella mount.
b. The only application for a longer cable, is to use the Cactus as a shutter trigger. that must be it.
Other than the above, why not just let the flash stand on the top shoe of the trigger? Not sure why folks want longer cables?
