07-22-2014, 06:34 AM   #271
Class A's Avatar
QuoteOriginally posted by WPRESTO Quote
MUCH more reliable triggering, but not quite 100%.
Whether you use hot-shoe or sync-cable triggering, shouldn't make a difference, unless there is some electrical issue with the hot-shoe.
The minimum near distance of 30cm is a possible source of misfiring as I am sometimes holding the flash right against the 200 macro to get near shadowless lighting, almost like a ring light.
I'm not saying the minimum distance is 30cm. It can be really quite small depending on from which angle you approach the V5 with the RF60.
I've done quite a bit of macro shooting in the same style as you do (using radio triggers and hand-holding both camera and flash, sometimes very close to each other) and experienced misfires due to coming below the minimum distance. The V6 had the same limitation and I asked Cactus whether they could at all optionally reduce the transmission power to gain better minimum distance tolerance in return for loss in long range performance. Luckily, after a while, they responded with a firmware update for the V6 that included the "SHORT" range feature.
With the V5, it can help to just rotate the RF60 around its long axis. This doesn't change the lighting, but can influence the minimum distance tolerance.
07-22-2014, 06:43 AM   #272
WPRESTO's Avatar
Thanks for the additional tip.
01-21-2019, 10:30 PM   #273
Thank you for the insight. My K70 has a shutter release of 3.5mm and so does the Cactus V5. It is stated "The required camera remote trigger cable is camera-specific and an optional accessory. Luckily, for Pentax users the required cable is a standard 3.5mm male to 2.5mm male audio adapter cable, such as this one." I have hooked up using the 3.5mm cable but cannot get it to fire the shutter. Tried the exact techniques the article stated to do. Hope someone can help.
01-22-2019, 04:54 AM   #274
Class A's Avatar
QuoteOriginally posted by FLOSSEY Quote
Yes, but the K-70 uses a four-pole type and hence doesn't work with standard Pentax remote controls or standard Pentax remote shutter cables.
You should be able to make your own cable by observing the standard pin layout of the 3.5mm cable coming from the Cactus V5 (I haven't verified the described layout but it sounds right and you can easily try both variants of swapping the "AF" with the "release" cable).
I don't think Cactus sell a K-70 specific shutter release cable but you can always write to them if you are not comfortable constructing your own cable.
You may also try your luck with a 3-pole to 4-pole adapter, as it apparently exists for the Xbox. I don't have any personal experience with one of these, though.
Hope this helps.
01-22-2019, 10:36 PM   #275
Hope this helps.
Thank you for your response. I will contact Cactus for a cable
batteries, cactus, camera, flash, flashes, gadget, infinity, lighting, metz, mode, operation, photo studio, shoe, strobist, transmitter, trigger, v4, v5
radio TTL flash trigger marinb Flashes, Lighting, and Studio 4 01-29-2010 01:41 PM
Review: FlashWaves Radio Flash Trigger after 7 months Genes Pentax Flashes, Lighting, and Studio 15 11-26-2009 12:50 PM
Calumet 4 Channel Radio Flash Trigger? CalendarGuy Flashes, Lighting, and Studio 0 02-15-2009 02:35 PM
How not to test your Cactus Wireless Flash Trigger xs400 Post Your Photos! 7 02-10-2009 07:01 AM
White Lighting Radio flash trigger smokey Flashes, Lighting, and Studio 0 03-11-2008 05:23 PM
All times are GMT -7. The time now is 04:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
