Originally posted by jake14mw My main criteria for these is reliability. You did not really talk about this much in your review.
Perhaps I didn't because it wasn't an issue. I never had any misfires. The only way to provoke misfires I found was to put receiver and transmitter too close to each other.
Originally posted by jake14mw 1) How did you get your units to test?
I had some email conversation with the manufacturer about the Cactus V4 a while ago and I guess they liked the probing nature of my technical questions. Anyhow, recently they asked me whether I were interested in becoming a member of their V5 beta testing team. They cannot possible test a new version on all equipment out there so they used a team of beta testers to have them test the units with their equipment and also provide feedback.
I thought they came up with a really nice trigger and hence thought I could share my impressions in the form of a review. It is really rewarding to see that many people seem to find it useful.
Originally posted by jake14mw 2) Did you test just one pair? It seems that with many other of the cheaper triggers, reliability problems are much more prevalent when working with more than one flash.
I used three units, testing the multi-channel option and switching the active flash on the fly. It was really nice to be able to setup a number of flashes in a room and then use the one that works best for a given situation or all of them.
Originally posted by jake14mw 3) You did use the words rock solid in your review, does this mean that you had 100% trigger reliability at 1/180th of a second?
Yes, no misfires, no banding. I tested the banding with "white wall" tests and with real life shots. I didn't have any issues at all. That's no wonder because the triggers could handle up to 1/1000 sync speed.
Originally posted by jake14mw 4) What Pentax bodies did you test them on and what flashes?
Pentax K100D. I'll see whether I can test them on some other bodies but to be honest, it shouldn't make a difference.
Flashes:
- Canon 540 EZ (trigger voltage <6V)
- Centon FG105D (trigger voltage ~5V, IIRC)
- Vivitar 2500 (trigger voltage ~13V)
- Sunpak GX 24 (trigger voltage ~56V)
Note that the Centon FG105D won't fire through the hot shoe with any receiver (Cactus or not) because it requires digital communication with the camera to release the centre hot shoe contact triggering. I triggered it using the 3.5mm sync socket I added with a
modification.
Originally posted by jake14mw One feature that looks great to me is the fact that you can mount another trigger in one of these. I'm hoping that this allows people that have a different existing set of triggers to hopefully get creative with some configurations.
It worked great with the Cactus V4 (433 MHz). Not sure how it will work with other 2.4GHz triggers. It won't be necessarily a problem because "2.4GHz" when used for radio triggers actually denotes a band of several possible frequencies. However, I wouldn't completely rule out the potential of interference.
