Originally posted by spyglass Does anyone know of an economical mount / adpater that will fit on the bottom of a flash for attaching to a tripod? I am just looking for a plactic unit that has a thread fitting for tripod mounting when I use my second flash as a remote. I see that the 540 comes with one (why Pentax cheaped out and never included one with my 360's is beyond me. Is it possible to buy the 540 plastic mount by itself?
I wish that Pentax would have spent a bit more money designing their flash units. The 540 appears to be cheaply built and has jamming promblems. Several camera shops all warned me off the 540 saying that the pile of dead returned ones was starting to block out the sun. The battery door on the 360 is incredibly flimsy and is just waiting to break (and I treat them like my first born). I see my old Vivitar flash sitting on the shelf (the one I used to use on my Pentax K1000 (but am terrified to use on my *ist for fear of too high a trigger circuit voltage and possible damage to the DSLR) and believe that it would with stand a nuclear blast and shake my head.
Any help of the mount issue would be greatly appreciated, as would any comments about the quailty of the Pentax flash units.
Thank you,
Don't bother using the cheap plastic mount that comes with the AF540-FGZ flash. I think it's more for display than actual use since it will probably break easily.
Go to a camera store and ask for a
cold shoe flash mount that can screw on to the top of a tripod. They should know what you are talking about. I bought a couple of these, used, from a second hand camera shop for about $20 each. The top is a cold shoe mount and the bottom has a 1/4" screw in for mounting to the tripod. I attach these to a cheap lightweight tripod and it's a great tool for off-camera flash since the tripod is adjustable in height.
If they only have hot shoe flash mounts then you can simply lay down a piece of electrical tape over the contacts and
voila! you have created a cold shoe mount.
If you don't have a local camera store then online stores like Vistek or chez Henry's stock it.
HTH
