Originally posted by SOldBear OK, got it.
Essentially you need an adapter to convert from a female PC port to a 2.5mm plug. The 2.5mm plug is then plugged into the wired shutter release of the K10D.
It can be done. But I think it's easier to buy something like a Yongnuo RF 602.
Or if you have an infrared remote control already, put the flash meter in "non-cord" mode and use the infrared remote to fire the camera.
Side note: I hope you're using a non-A lens, otherwise you'll be using the built-in flash in p-TTL mode. The preflash strobe will trigger the remote flashes.
thanks for the info. the main reason I wanted to go with the wired mode with the flash meter according to the usermanual the non cord mode might not measure a flash below ambient light level, so in order to measure say 1/2 stop below ambient light you need to go cordless.
any idea where to get the adaptor?
I do want to go with a radio trigger in the future
randy
