Originally posted by DSims Of course, if you're just trying to get the corresponding f-stop for proper exposure, you can measure at one of those speeds and then add or subtract 1/3 stop from the reading you get, which will be correct for 1/160s. So for example, if the meter reads f/8 and 1/125s, you would set your camera to its equivalent, at f/7.1 and 1/160s.
This is correct if you measure
ambient light, but doesn't apply in flash metering.
Unless the ambient light is really bright, or the flash is really weak, I bet you the meter gives the same reading whether you set it at 1/125 or 1/160 or 1/180 or 1/200.
