jjhenders - the pricing should be almost identical. At that price difference it's not the same unit. No you can NOT use a unit labelled Canon / Nikon on your Pentax camera (power values, for one thing, will be different) - same applies to any flash unit with TTL, however the same doesn't apply to manual flashes - THOUGH YOU MUST MAKE SURE THE VOLTAGE IS COMPLIANT WITH YOUR CAMERA !
Manual flashes can be an excellent, and much cheaper, way to get into strobing. However whether you need P-TTL or not depends on your specific uses.
At home the Yongnuo 560 (and any other manual flash like it with a rotating zoom head) is great because it has excellent controls and you will want to be bouncing the light of ceilings and walls anyway - for direct light just use your pop-up with a little cloth or other diffuser on it and control the amount of power output via your on-camera flash control.
Outdoors any dedicated flash unit will have far more power to throw the light further.
Moving Subjects : Simplifying matters to an extreme : flash freezes the subject (your shutter speed doesn't matter so much with moving subjects - the flash is only on for about 1/10,000 of a second and it's THAT that freezes motion.
You'll get more 'keepers' with P-TTL as it automatically controls the flash output for subject distance, but you'll still get a lot of great shots with a manual flash unit.
