05-02-2011, 06:30 AM   #1
If you could only have one TTL flash..
Hi there. If you could only have one TTL flash--$150 or less--to sit on top of your Pentax camera, which one would you pick?
I want a TTL flash for capturing events. I want something reliable, consistent and flexible. I am going to order 2 x YN-560's for off the camera; manual flashes are fine for that.
It would be nice if the TTL flash that I'd be getting, would function decently as a manual flash to go along with the YN-560's, for studio work.
I am getting some decent captures with the pop up flash using a custom bounce card I made, but I imagine having a larger TTL flash atop the camera would be better.
05-02-2011, 06:55 AM   #2
boriscleto's Avatar
If you look really hard you can find the Sigma EF-530 DG ST for around $150. 47st Photo might have some. The EF-610 DG ST is less than $170.
The Definitive Guide - Pentax P-TTL Flash Comparison
05-02-2011, 07:13 AM   #3
I'd want a P-TTL that'll work wirelessly so I could hand-hold it to the side occasionally for macros as well as portraits. I think that argues for the super sigma given today's market.
I guess my suggestion is for you to rethink your "on-camera" specification as less expensive flashes like the Rokinon 980 will satisfy your needs as given.
I have a $100 Rokinon 980 and a wire; it works flawlessly in P-TTL on & off camera; I'd gladly give it and $60 for a flash that'll work in wireless P-TTL mode.
camera, flash, lighting, photo studio, strobist, ttl
Difference between TTL and P-TTL flash. rod_grant Pentax DSLR Discussion 46 11-15-2017 10:05 PM
P-TTL flash for K-x Pentax Bob Ask B&H Photo! 7 04-15-2011 04:46 PM
P-TTL flash - is it necessary ? Squier Pentax DSLR Discussion 35 10-27-2010 12:55 PM
Non-P-TTL AF Flash trailrider Pentax DSLR Discussion 5 07-21-2010 06:04 PM
All times are GMT -7. The time now is 05:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
