Does an umbrella like the following exist? (If not, I should make one using a shoot through umbrella as a starting point.) :
1. Base umbrella being a shoot through.
2. Has a dome cover which is black on the outside and solid bright white (or silver?) on the inside, to place over the convex side (top) of the umbrella.
3. Has a white--shoot through type fabric--fitted bottom cover with a hole in it for post to go through and for flash to point in.
4. Has a black, with white on the inside--fitted bottom cover with a hole in it for the post to go through and the flash to point in.
It seems like all these umbrella fabric accessories would be useful:
1. The umbrella can be used as a standard shoot through umbrella.
2. It can be used as a standard reflective umbrella (with the black dome cover on).
3. It would allow the umbrella to function as a pseudo softbox--with the black dome cover on and the white flat fitted cover on the bottom.
4. You could use the umbrella as a shoot through with added bonus of control of light leakage using the black fitted bottom cover.
I can sew all this stuff using a shoot through umbrella as a base i guess. Using velcro for the top cover and elastic fitted for the bottom. Would be pretty easy.
If I had a couple of these, say in 45" size, would it pretty much eliminate my need for other umbrellas or softboxes? I am assuming I can use gels on the flash in lieu of gold reflective umbrellas. I don't know about silver; do I need this or what can I do besides add another layer of velcro-able fabric?
