05-26-2011, 06:59 AM   #31
Digitalis's Avatar
Here is the lighting diagram of the motorbike image - it's always useful to make a diagram of the lighting you used - you never know when you will need to use a similar set up and it will give you an idea of the results you will get from it. - and a flimsy pretext to make my 2,000th post!
05-26-2011, 07:02 AM   #32
eddie1960's Avatar
I use the honlphoto Gel system - because I use Canon, Pentax and Nikon flash gear, having gels that can be interchangeably used on all three systems is very useful for me. The filters are attached by a Velcro 'speed strap' that is rubberised on the other side to give the strap a good grip on the flash - no adhesives are used. The gels are about 4"X4" square and are attached to the flash Via the speed strap - the gels are big enough to be used on a Nikon SB 900 or AF540FGZ.
Honl also make snoots,gobos and reflectors that can be attached to the speed strap - which makes it a very versatile system to work with.
I use the really strong colours for backgrounds, just put a gel on the flash and fire it at a neutral coloured wall and you can create some nice effects, as you can see there are a wide variety of colours - colouring the background is very useful to create some 'pop' to portraits.
+1 on the Honi System I use their Gels as well, primarily the CTO to compensate for Tungsten.
book, filters, flash, gel, lighting, neil, on-camera, photo studio, portrait, strobist, van, wedding
Adverse effect of Silica Gel on Lens? yusuf Pentax SLR Lens Discussion 8 11-17-2010 10:01 AM
Macro Hey that Hair Gel......... eaglem Post Your Photos! 2 08-10-2010 03:29 AM
What kind of Silica Gel do you use? LeDave Troubleshooting and Beginner Help 11 08-07-2009 02:54 PM
How do you gel/mod your flash? jms698 Photographic Technique 9 12-17-2008 05:26 AM
Flash Gel Kits (Corrective & FX) spyglass Flashes, Lighting, and Studio 0 02-15-2008 10:41 PM
All times are GMT -7. The time now is 01:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
