Originally posted by liukaitc here is the pic. the uppart looks no good. is that because the ceiling is so low? I just flash straight upward, bounce to ceiling. bare flash, no any diffuser kind thing attached.
Anyway not only this pic. I shoot a lot indoor event. In club, resturant, party kind of places. I find many of my photo the uppart is too bright or has nasty reflection. I point my flash head staight up all the time.
Help!! How to improve my flash skill. First I think must buy some diffuser kind thing? Right? second, is that always bounce to ceiling when indoor? but if flash directly to the subject, it would be worse..so I guess no other option??
In your first pic, it looks like your flash might be contributing directly to the upper part of the mega-bottle there. Look at how there's a harsh shadow cast on the ceiling behind the bottle - that's a sign of direct flash contribution.
You may in that case need to angle the flash backwards behind you a bit, so the part of the ceiling you're bouncing off of is a bit farther from the subject (but be careful that it's not so far back that you cast shadows yourself).
Also play around with the flash zoom settings - Wide angles provide a very diffused light source, but with greatly increased risk of direct flash contributions. Zoomed flash provides a smaller bounced light source but it is unlikely to contribute direct flash to the photo.
My experience with the diffuser on the AF-540FGZ is that it causes a LOT of light leakage to the sides of the flash and even downwards (for a flash pointed straight up) - it is extremely difficult to avoid significant direct contributions when using the diffuser.
As to your second image, which appears to be of a real soy bottle that is fairly reflective - specular reflections are VERY difficult to control unfortunately.
