05-27-2011, 07:35 AM   #1
Deiberson's Avatar
X Sync Socket with a K5 and Adorama Mono lights
Not sure if I should post this in here or the K5 forum so I might double post.
If have a pair of Adorama 620 Mono lights. They came with the sync cord. Is this cord just used to fire the lights or......will it carry the TTL info into the mono lights from the camera? I always assumed that I have to shoot the mono lights in manual via the speed dial.
I'm also assuming that I have to fire the 2nd mono light and whatever other speedlights that I have as a slave since I can only have 1 cord....correct?
Thanks
Kevin
05-27-2011, 08:12 AM   #2
enoeske's Avatar
The strobe doesn't know p-ttl and I'm pretty sure the sync cable and socket only pass through the "fire" command. No p-ttl with monolights.
05-27-2011, 07:13 PM   #3
philbaum's Avatar
QuoteOriginally posted by enoeske Quote
I've been reading a book on flash techniques, and it states that studio lights like monos have always been manual. i don't know if thats still true or not.
adorama, cord, fire, flash, k5, lighting, lights, photo studio, post, strobist, sync
x sync socket Chuckster Pentax DSLR Discussion 0 02-17-2011 08:01 PM
Outrageously expensive X-Sync socket caps... any other source? Timichango Pentax DSLR Discussion 9 07-21-2010 03:30 PM
PROBLEM: Genesis 400 strobe lights w/ K-7 not working w/ sync cable slappy76 Pentax DSLR Discussion 8 02-27-2010 04:32 PM
K20D flash sync socket problems flexidan Pentax DSLR Discussion 2 10-24-2009 04:19 PM
PC sync socket on K20D Anya Troubleshooting and Beginner Help 6 05-15-2009 08:28 PM
All times are GMT -7. The time now is 03:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
