Originally posted by adwb question for YN560 owners
I have 2 of them that both exibit the same behaviour.
When switched on the units remember any previous settings that were set in place at the time of being switched off except the zoom setting that defaults back to the 105 position every time.
Is that a common situation or is my units?
I found this quote on speedlights.net
Quote: Like for the power level the YN-560 also recalls its current zoom reflector position when powered off and on again (an advantage over the YN460 Mark II).
I just tested my single one, purchased recently, and it recalls the last zoom setting. Sounds like they may have changed the programming from the 460 so perhaps you got an earlier 560 issue with slightly different programming. I don't know of anyway to change it. For the money, hard to beat.
