As stated, I have experience with 45CT-1 & 4, and 45CL-4. I've never used the 45CT-5. What I write below is based partly on my experience with Metz flashes and partly on what I learned on the internet.
All Metz 45CT models have the same guide number: 45 (meter, 35mm FOV, ISO 100). The CT-4 and CT-5 have a "secondary reflector" that can be used as fill flash (15% power) when the main head (85% power) is in bounce position. IMHO, in most cases, the light from the secondary reflector is too powerful. A "neutral density" lens is available for the secondary reflector. It reduces the output of the secondary reflector by 40%.
The main head can tilt from 0 to 90 degrees (straight up), and rotate from -180 to +180 degrees.
In auto mode, there are 6 aperture settings. The light sensor is very accurate. There are 2 manual power ratio settings: full and W (for "winder," 1/40).
The accessory "Mecamat 45-30" (somewhat rare) will give you more control of the flash, including 7 manual power settings (from full to 1/64) and 8 (I think) aperture settings in auto mode. Note that other Mecamat models don't work with the 45CT-5.
60CT-1, 60CT-2, and 45CT-5 share the same sync cord, Metz model 5524. This sync cord has a PC terminal. I've seen sync cord that works with camera's hotshoe but don't know the model number.
I don't think the 45CT-5 supports TTL or p-TTL.
